1995 Nissan Maxima water pump replacement
CARYANDREG
  • 1995 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 198,000 MILES
Need a link to a procedure on how to change out the water pump. Pump has chain sprocket, I assume it lives under the timing chain cover, whats the easiest way. Remove motor mount then remove chain cover or are there inspection covers for the chain tensioner and water pump?
Friday, April 17th, 2009 AT 11:59 AM
BUDDYCRAIGG
  • 2,262 POSTS
Those are rough.
Spend the 15 bucks for a manual at a parts store.
You'll really appreciate having those pictures and diagrams next to you while you're taking it apart (keeping the cam timing correct)
and when you are putting it all back together.
Friday, April 17th, 2009 AT 12:43 PM
