1995 Nissan Maxima Transmission maybe???
192,000 MILES • 6 CYL • 2WD • AUTOMATIC
KWARREN517
hey i heard about this site in playboy and i'm a girl that needs 2 car pros! I think that i may have a problem with my transmission I plan to flush it asap but before I did that I was hoping for a little help. I have never owned a nissan and got this one for free. I have no idea where the drain plug is and could use any info anyone has. the car came with NOTHING I have no manual. It has starting shifting out of 1st a little too hard for my liking and has a bit of a rough ride in 1st gear. when it idles it is kinda chuggy, that's the best description i can give. If i put it in neutral it is a little less "chuggy" I know it needs an oil change i'm doing that as soon as it stops raining but help this little girl out. I don't know too much but with a little help i'm sure i can figure it out! Thanks!
Jul 30, 2009 at 7:44 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated I suspect you may have a fault on the transmission internally and a flush will not cure the fault ... you posiibly have a faulty solonoid or torque convertor .. you really need to have the transmission looked at by a transmission shop ... Hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_900.png
Jul 30, 2009 at 12:08 PM
  • 55,673 POSTS
wow,, I have not heard of the that, does anyone have the issue, I would like to see it,,,,hehe
Aug 4, 2009 at 4:26 AM
STEVEW84
  • 673 POSTS
Sounds like it might be a bad trans or maybe the converter is staying locked. I would like to know if there are any codes in it first. I know its an obd1 (need an obd1 connector)but depending on what month the 95 was built is might have an obd2 connector that works also.
Aug 4, 2009 at 5:00 AM
