1995 Nissan Maxima The Needle of the C-H goes up all the wa
176,000 MILES • 6 CYL • FWD • AUTOMATIC
DUONGLUCLANG
I have a question. The needle of the C-H goes up all the way when i drive the car for 5 or 10 minutes. It goes all the way up and then go down a little, then it goes back up to the H area again. When i check the coolant, i realize the coolant is low but then when i pour in the antifreeze/coolant, the problem still there. After i pour in the coolant, i go for a test drive. The needle still goes up all the way to H and goes back down little and goes up all the way again. It just doesn't stay at one place, it goes all the way up to H, then back down little and then back up again. Please help me out and tell me what i should do. Thanks
Kenneth
Apr 9, 2009 at 11:25 AM
  • 75,988 POSTS
Replace the thermostat and see what happens-don't work come on back
Apr 9, 2009 at 11:30 AM
DUONGLUCLANG
I have another concern before i go change the Thermostat. Yesterday, when i come back from the test drive, feeling depress i park the car. I come out to open the hood 30 minute later, i come to realize that the coolant leak. I pour the coolant to the maximum, however, when i check it again, it leaks out. I pour the coolant in again and massage the hose and go for another long test drive. this time the thermostat doesn't idle anymore. And when i open the hood to check the coolant, it doesn't leak. Can you tell me what is happening? why the coolant leak and all the of sudden, i pour in the coolant again and go for a test drive, the thermostat no longer idle. Thanks
Kenneth
Apr 10, 2009 at 3:44 AM
  • 75,988 POSTS
Are you actually overheating ?
Apr 10, 2009 at 10:11 AM
DUONGLUCLANG
No, my car hasn't overheating yet.
Apr 10, 2009 at 12:25 PM
  • 75,988 POSTS
Get it block and pressure tested you're losing coolant somewhere.
Apr 10, 2009 at 12:38 PM
