1995 Nissan Maxima check engine light
1995 NISSAN MAXIMA
125,000 MILES • 6 CYL • FWD • AUTOMATIC
OZL32
Hello i pulled codes from my maxima and got 34 and 15 i think i read them right 3 slow flashes and 4 fast flash 10 slow and 5 fast. One thing that i notice i feel a slight surge sometimes when i drive it but doesn't really die out. just for a split second and like it missies a signal or something. also i think it needs and igniton switch because i have to turn it all the way and jiggle it. Thank you i would aprreciate answer back
Jul 4, 2010 at 6:48 AM
Try clearing it and recheck again
Diagnostic Trouble Codes - 1995
Nissan
11 Crankshaft Position Sensor
12 Air Flow Meter
13 Engine Coolant Temperature Sensor
14 Vehicle Speed Sensor
21 Ignition Signal
22 Fuel Pump
31 Engine Control Unit
32 EGR Function
33 Oxygen (O2) Sensor
34 Knock Sensor (Turbo Only)
35 EGR Temperature Sensor
43 Throttle Position Sensor
45 Injector Leak
51 Injector Circuit
54 A/T Control
55 No Faults In Memory
Could be the oxygen sensor not switching accordingly
Jul 4, 2010 at 7:47 AM
OZL32
Thank you for your response just how exactly is the proper way to eRASE THE SES LIGHT? would disconnecting the battery help?
Jul 4, 2010 at 8:46 AM
You can try it that way if not use a scantool if it continues to comeback you have a hard code that needs to be dealt with.
Jul 4, 2010 at 10:03 AM
