1995 Nissan Maxima
175,000 MILES • 4 CYL • 2WD • AUTOMATIC
TWINDADDY
my car duts off & if you let it sit awhile it will crank back up. I've changed the fuel pump, fuel filter, fuel relay, & alternator
Feb 22, 2010 at 7:32 AM
  • 31,937 POSTS
Hi there,
Check for any fault codes in the ECU (you don;t always get a check engine light showing with all codes) you may have a sensor that is failing due to overheating and working again when it cools down, start here.
Mark (mhpautos)
Feb 22, 2010 at 7:37 AM
TWINDADDY
What sensor could it be
Feb 22, 2010 at 7:39 AM
  • 31,937 POSTS
Could be a cam or crank angle sensor as these are reference sensors for ignition & injection, a scan should give a code if one is faulty.
Mark
Feb 22, 2010 at 7:41 AM
  • 31,937 POSTS
Ohh also, coils can do this as well but not as common and you usually get a miss fire with a coil acting up.
Mark
Feb 22, 2010 at 7:42 AM
