Did you find them if your motor is 3.0 v6 twin cam this should show u can you see the nissan cover its plastic its on your motor use allen key to remove the four screws then you will see 3 unscrew and theirs your spark plugs then u have 3 more on the back you can spot them easy unclip them then change your spark plugs nice helping good luck
SPONSORED LINKS
Sunday, October 4th, 2009 AT 9:50 PM
