1995 Nissan Maxima
1995 NISSAN MAXIMA
HGUZMAN08824
Drive Train Axles Bearings problem
1995 Nissan Maxima 6 cyl Front Wheel Drive Automatic
i'm trying to replace the right side drive axle i removed evrything to where i got the axle out from the spindle but for some reason or other i can not get the damm axle out of the trans any ideas or am i missing something--HELP
May 4, 2008 at 4:01 PM
MASTERTECHTIM
  • CERTIFIED EXPERT
  • 4,750 POSTS
does the axle go right to the transmission? if it goes right to the transmission without a stabilizer bearing then all you have to do is pry and pull out the axle. sometimes you need to bang on axle with a hammer while prying it out at the same time
May 4, 2008 at 4:04 PM
