1995 Nissan Maxima
1995 NISSAN MAXIMA
HARRYDAG
Engine Performance problem
1995 Nissan Maxima 6 cyl Front Wheel Drive Manual
My 1995 maxima Check Engine lite has been on for 6 months with no apparent problems or power loss. Recent computer analysis indicates mass air flow sensor and oxygen sensor problem codes. Since then I let my engine over heat.
1. Is there another way, besides looking for coolant in my motor oil, to find if I blew the gasket or cracked the block?
2. Could a bad MAF cause such erratic infrequent sputtering as discussed below?
My radiator is cracked and caused overheating when I failed to watch water level and the engine sputtered badly and lost power until I added water. However, approximately 2 weeks later, with a full radiator, my auto started erratic, power loss, sputtering “fits” when starting from idle at stop signs and lights, but, oddly, this occurs only roughly once in 25 such starts.
I cleaned the MAF hot wire and she ran great, but immediately regressed to her “fits” now roughly once per 35 starts. One mechanic feels the MAF wire is bad.
Nissan ran their computer diagnosis, found the same problem codes with Oxygen and MAF sensors. Nissan feels the culprit is the MAF.
But first, before I invest $950 for sensors, I want to check if my engine block or gasket is cracked from the overheating. Nissan looked for coolant in my engine oil but said they couldn’t determine any leakage because I had recently changed my oil. I have fearfully driven this car about 90 miles merely to see if coolant will leak into the motor oil.
Aug 12, 2008 at 6:28 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation.
There are a few ways to determine if you have a head issue, the most reliable method is to test the coolant for exhaust gasses, this is done as a chemical test and is very reliable, it will not determine where ether problem lies, only that there is a combustion leak into the cooling system. The MAF sensor is one of a number of "inputs" the ECU receives to manage the running of the engine. If this input signal is country to the actual conditions,say low air flow at high speed running the ECU may alter the fuel injection duration or adjust the timing in accordance with this signal, which will cause a rough running condition or a miss fire or low power and poor performance. I hope this helps.
mark (mhpautos)
Aug 12, 2008 at 10:46 PM
