1994 Nissan Maxima Timing belt repaired but wont run still
223,000 MILES • 6 CYL • FWD • AUTOMATIC
CRSNORMAN
My timing belt broke. I replaced it, I got the timing marks on the belt, cam sprockets, crank sprockets, alined with the markings on the rear timing cover for the top two and the mark on the oil pump for the crank shaft. I have to hold the gas to the floor to get it to start and keek it above 1000 rpm to keep it running. It runs rough and dies when I let off the gas at about 800 rpm. What did i do wrong or what am i missing. the car was running ok untill the belt broke. Please help!
Aug 9, 2010 at 8:31 AM
DOCFIXIT
  • 18,828 POSTS
Hate to be the bearer of bad news but the engine is an interference engine that means when T-belt brakes pistons hit valves and bend. Run compression test you will see by low or no compression in some cylinders
Aug 9, 2010 at 8:40 AM
MADMIKE1735
  • 951 POSTS
agree with the previous statement... i highly suggest not replacing the head thinking that will soive the problem.... find a good used engine and have it installed... once internal parts go, they usually never run the same afterwards...
Sep 2, 2010 at 2:51 PM
