At 130000 I replaced the fuel injectors using rebuilt injectors since two were open when checked with an ohm meter. After 3000 miles I got some rough performance when I started the car on a cold morning. Checking the error code I got 51 which indicates an open in the injector circuit. However before I could check it out the problem cleared. I suspect it's going to come back. Is this a typical problem with injectors and should I get new ones rather than rebuilt if I need to replace them again?
Feb 1, 2007 at 5:16 AM
