1994 Nissan Maxima DOHC VE30DE Strange Electrical Behavior
150,000 MILES • 6 CYL • FWD • MANUAL
JERREAU
Electrical
This past weekend, I replaced the passenger side wheel hub and bearings on my car. In order to replace the bearings I had to remove the steering knuckle and take it to a machine shop, which means removing the ABS wheel speed sensor. I removed it and reinstalled exactly as it was.
Since I finished and began driving the car, I have notice/endured several electrical problems, including but not limited to:
-Power Window/Lock Failure, on all doors.
-Radio shorts out and ejects CD--coincides with depression of brake pedal.
-Power fails on entire car. no crank, no interior lights.
-Power seatbelts fail to release upon door open.
-Instrument Panel and Headlight flicker.
The brakes appear to be operating correctly, but some of the malfunctions appear to coincide with pressing the brake pedal.
Sep 4, 2009 at 3:59 AM
MERLIN2021
  • 17,250 POSTS
All I can think of is a loose ground, check these and all electrical connection near the strut or strut tower you may have accidentily knocked loose/off.
https://images.2carpros.com/forum/automotive_pictures/62217_maxima_2.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Maxa_1.jpg
https://images.2carpros.com/forum/automotive_pictures/62217_Maxb_1.jpg
Sep 5, 2009 at 3:21 AM
JERREAU
When I rebuilt the Hub, because the hub was warn, I used a copper shim, and some epoxy between the inner hub and the bearings. It has worked in preventing the hub from wobbling, but could that cause a grounding problem? Also, could a damages ABS speed sensor cause some sort of electrical shorting?
Sep 8, 2009 at 4:23 AM
MERLIN2021
  • 17,250 POSTS
Maybe, but is the ABS light out now? And check the connections at the battery terminals, these corrode and give tons of headaches.
Sep 8, 2009 at 8:36 AM
