1993 Nissan Maxima wont idle- rpms race up and down
1993 NISSAN MAXIMA
135,000 MILES • 6 CYL • FWD • AUTOMATIC
1TRIMMER
replaced tps switch, coolant temp switch, fuel filter, mas air flow sensor, air filter, new plugs, used sea foam in tank, new gas cap. If you try to hold gas pedal at 2000 rpms , the engine races to 2500 then back down to 1500 then back up again etc.wont idle, goes up and down just not as severe. when driving it boggs down with no power at alll (stall) then it will pick up again! Any magical thoughts?
Aug 31, 2009 at 5:03 AM
Check the FICD and the IAC-AAC valve
Aug 31, 2009 at 8:31 AM
