1993 Nissan Maxima power window and sunroof
CHERIE1037
1993 Nissan Maxima 6 cyl Front Wheel Drive Automatic
all the windows including the sunroof will not work except the passanger side which rolls up and down with the passanger control. using the master control on the drivers side will only roll the pasanger side down not up.
Nov 3, 2010 at 7:35 AM
KHLOW2008
  • 41,812 POSTS
Hi cherie1037,
You need to confirm that the motor for all the windows that are not working to be good. You need to remove the door panel to test the motors with external battery source.
For the passenger front window perform the following test to find out what is wrong. If driver's main switch is found to be faulty, replace it and test if other window works.
PASS WINDOW(S) WORKING FROM DOOR SW ONLY, NOT FROM DRIVER'S SW
1. Remove 10-pin connector from passenger window switches. Turn main lock switch to OFF. Check voltage between Green/White or Green wire terminal and ground.
2. With main switch in UP position, 12 volts should be present. With main switch in DOWN position, about 4 volts should be present. With main switch in neutral position, about zero volts should be present. If voltage is as specified, replace window switch.
3. If voltage is not as specified, disconnect 12-pin connector from driver's door switch. Check for continuity between Green/White or Green wire at passenger door switch connector and Green/Red, Green/Black and Green/White wires at driver's door switch connector.
4. If any circuits are open or shorted to ground, repair circuits. If no problems with shorts or open circuits are found, replace driver's door main switch.
© 2008 Mitchell Repair Information Co., LLC.
For the sun roof, is system equipped with digital touch?
Nov 5, 2010 at 2:54 AM
