My 1993 Nissan Maxima {automatic transmission, } will go into reverse & neutral. It will not go into forward driving gears. Whay can I do / check?
I've checked fluid, it's alright.
Saturday, July 5th, 2008 AT 12:59 AM
DONALD9251
MEMBER
There is nothing else you can check. A shifting gear is worn-out or broken in your automatic transmission. You need to take your car to a transmission shop and get the transmission repaired (which will cost almost $2000) or put in a good used transmission (purchsed from a salvage yard) or you can just junk the car. If it were me I would just junk the car (could come down with an engine problem soon after the transmission is fixed) and buy another one.
