1993 Nissan Maxima fuel pressure regulator or what?
1993 NISSAN MAXIMA
240,000 MILES • 6 CYL • FWD • AUTOMATIC
SMELT
i notice one day that my when I started my car, as soon as I put it into drive it shut off. Then I started again in Neutral In thru It in reverse It did the same thing... So I stop to check under the hood I noticed my egr valve was leaking also I a hose leading from the valve was cracked and leaking. I pursued to changing the valve and hose... But after that my car wouldnt start at all.. It would just turn over but not catch. I check the engine oil level. and smelled and seen gas mixed wit oil on my dip stick... I drained my oil pan and there was a mixture of both in my pan... WHAT HAS HAPPEN AND HOW TO I FIX IT... my mechanic told me its my fuel pressure regulator...is that true... Please help me
Nov 5, 2009 at 9:51 AM
Check the fuel pressure regulator vacuum hose does it have fuel-if so the regulator is ruptured, also
Nov 5, 2009 at 10:02 AM
