1993 Nissan Maxima Cannot Fire after head change
1993 NISSAN MAXIMA
193,000 MILES • 6 CYL • FWD • AUTOMATIC
STOKA69
Hi all. I have a 1993 Maxima and after I had changed the head (closest to the firewall) and aligned all the sprockets for the timing at TDC, the car will not fire up. I changed the dirtributor location to the number one terminal with cylinder #1 at TDC (per Haynes Manual) and still nothing. Everything is connected correctly, vaccuumm hoses, fuel and electrical hoses. I know there is a spark and fuel delivery. Please help!!!
Sep 23, 2009 at 12:34 PM
Is the fuel pressure correct?
All you need now is the correct valve and ignition timing and she'll fire right up. You sure no.1 is not on the exhaust stroke
Sep 23, 2009 at 6:20 PM
STOKA69
[quote:88ba5cfea9="rasmataz"]I know there is a spark and fuel delivery
All you need now is the correct valve and ignition timing and she'll fire right up. You sure no.1 is not on the exhaust stroke[/quote:88ba5cfea9]
Is it possible that the cylinder can be on the exaust stroke if it is in TDC? Isn't it always on the compression?
Sep 24, 2009 at 3:38 AM
Open it up and verify that no.1 is in the compression stroke-both valves on the no. 1 should be closed-Lining the crank pulley to TDC doesn't mean you're on the compression stroke-I'm guessing you're 180deg off
Sep 24, 2009 at 3:47 AM
