1992 Nissan Maxima Speedometer not moving
158,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHANCHER
My speedometer suddenly stopped moving. It's down at zero - does not move at all The engine RPM and odometer are OK. The car runs fine.
Is this something I can fix easily? How much could it cost if I took it in? I
s there a potential problem with the car that I should be concerned with - will the transmission suddenly stop shifting?
Please let me know. Thanks
Jul 28, 2009 at 9:39 AM
  • 75,988 POSTS
Sounds like the vehicle speed sensor when whack! inspect and test-VSS is used by the computer to command and control the transmission as per governor pressures.
Jul 28, 2009 at 9:46 AM
CHANCHER
Thank you for your response. Will there be a serious problem if I do not have the speed sensor fixed?
Jul 28, 2009 at 5:21 PM
  • 75,988 POSTS
Dunno the serious effects however if it malfunction it affects how the transmission shifts-best bet just get it fix when you can afford it.
Jul 29, 2009 at 4:41 AM
CHANCHER
Since the odometer and engine RPM gauges are working OK, does this mean that the transmission will not be affected?
Jul 30, 2009 at 3:26 AM
  • 75,988 POSTS
As long as the transmission is shifting okay-you're good to go the VSS only tells the computer how fast you're running and the computer uses it to monitor the governor pressure to provide upshift/downshift/overdrive/lock-up-could be bad connection or the gear in it has sheared off/out of alignment.
Jul 30, 2009 at 8:18 AM
MAXIMAFUN
Check all ignition fuses in the fuse cab/driver side
Aug 8, 2009 at 4:49 PM
CHANCHER
Thanks for the email. I did check the fuses, but will re-check.
Since the tachometer and odometer are OK, and the care runs fine, could it be a loose conection somwehere that's causing the speedometer problem?
Aug 8, 2009 at 5:16 PM
  • 75,988 POSTS
Check if the speedometer is cable driven could be behind the speedometer head or down at the transmission
Aug 9, 2009 at 7:05 AM
