1992 Nissan Maxima moon roof drain lines
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
SFRYE
  • 8 POSTS
I am aware that the moon roof on this 92' Maxima has four drain lines. I have been told by a repair shop that they are clogged and are the reason the moon roof is leaking. My question is how to clear the drain lines without inadvertently disconnecting the drain lines (which can happen by using an air pressure force I'm told) ? So, what are my options to clear drain lines? thanks' in advance for advice...........Steve
Feb 21, 2009 at 4:59 PM
MERLIN2021
  • 17,250 POSTS
Only two options: Using short blasts of compressed air, and removing the headliner for access, I use the air method, you may have a clean up to do when done!
Feb 21, 2009 at 10:57 PM
