1992 Nissan Maxima fuel pump relay location
10,000 MILES • 6 CYL • 2WD • AUTOMATIC
DEAN PLYLER
Oct 30, 2010 at 6:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
fuel pump relay, green in color, is located in the left side of the trunk near the taillight
Oct 30, 2010 at 6:30 AM
SY_BASE
There is no fule pump relay in trunk on my 1992 Maxima SE. Any other locations? I have a "FICD" realy in the engine compartment could this be it?
TANKS MUCH
Mike
Nov 8, 2010 at 9:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Assuming you have the DOHC motor then yes the FICD is it
Nov 8, 2010 at 9:48 AM
SY_BASE
Yes ir is a DOHC Thanks for your help. I Repalced the FICD relay still no fulel out of the fuel filter with the fuel line disconnected. Is there any easy way to be sure it is the fuel pump before I take the gas tank off? How difficult is it to remove the gas tank and replace fuel pump on 1992 Maxima?
Nov 8, 2010 at 11:31 PM
BLUELIGHTNIN6
  • 16,542 POSTS
when you first turn key without cranking do you hear fuel pump buzz for few seconds? if not, have helper bang on fuel tank with rubber mallet while you turn key , if it starts up then fuel pump is bad. if fuses, relay and wiring is good and pump is not running then it's most likely faulty pump.
Nov 9, 2010 at 11:31 AM
SY_BASE
As you instructed, I hit the gas tank with rubber mallett with the key in the ON POSITION(power to the electrical system and fuel pump). No gas came out of the open fuel line I had in engine compartment. I turned off the ignition then turned iginition on again the second time and there was gas pumping out... so it is working now.
So, does this sound like a bad fuel pump? If so the is $130.00 Delphi pump good enough or should I pay more $225 for OEM or Airtrx pump?
Nov 10, 2010 at 3:29 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Delphi is a good brand for fuel pumps and yes it does seem like the pump is at fault here.
Nov 10, 2010 at 6:59 AM
