1992 Nissan Maxima 6 cyl Front Wheel Drive Automatic
92 nissan maxima. Changed two injectors seals and o-rings replaced intake gasket (due to hesitation on two cyl.) Replaced intake. Now the injectors are dumping mass amounts of fuel into cyl. So much it stops the engine from cranking. So I pull the spark plugs disconnect the wire on the coil then crank it and the fuel gushes out. Changed the pressure reg. Any clues would help.
Wednesday, May 13th, 2009 AT 11:03 AM
