1991 Nissan Maxima rotary squeal
234,000 MILES • 6 CYL • FWD • AUTOMATIC
BLOB
rotary squeal at serpentine belt near back cylinder head, idler pulley replaced. constant squealing at idle, variable with engine speed. belt is tight . help driving owner nuts.
When weather is cold in the morning and car first started, no noise! After car warms up the squealing noise starts, and it sounds like there are two different noises sometimes.
Mar 24, 2008 at 4:47 PM
RACI47
  • 85 POSTS
check if the noise changes when you turn the steering wheel if it does your power steering pump is done for if it doesnt then the problem is one of the other items on the belt
Apr 8, 2008 at 3:41 PM
