1991 Nissan Maxima rotary squeal
BLOB
  • 1991 NISSAN MAXIMA
  • 6 CYL
  • FWD
  • 234,000 MILES
Rotary squeal at serpentine belt near back cylinder head, idler pulley replaced. Constant squealing at idle, variable with engine speed. Belt is tight. Help driving owner nuts.
When weather is cold in the morning and car first started, no noise! After car warms up the squealing noise starts, and it sounds like there are two different noises sometimes.
Monday, March 24th, 2008 AT 11:47 PM
RACI47
  • 85 POSTS
Check if the noise changes when you turn the steering wheel if it does your power steering pump is done for if it doesnt then the problem is one of the other items on the belt
Tuesday, April 8th, 2008 AT 10:41 PM
