1991 Nissan Maxima engine runs rough
166,000 MILES • 6 CYL • FWD • AUTOMATIC
JPM35
hi guys, My problem is with the engine running rough. This problem recently started. Engine starts ok, but seems to shake slightly in engine bay and exhaust makes a putt-putt-putt sound at tailpipe.Taking off from a stop and the engine seems a little sluggish and choppy sounding. I recently changed all six spark plugs ,but not cap and rotor as they appeared to be ok.
Sep 17, 2009 at 8:14 AM
DOCFIXIT
  • 18,828 POSTS
First check pluge see if one got loose and all wires are firmly seated. If all good need a compression test
Sep 17, 2009 at 8:18 AM
JPM35
I forgot to mention that this is problem is intermittent. Sometimes after starting the car it is fine , runs smooth. Other times it occurs.
Sep 17, 2009 at 11:49 AM
DOCFIXIT
  • 18,828 POSTS
Intermittent is a problem could be several things. Have you tried checking for codes in ECU?
Sep 18, 2009 at 4:39 AM
JPM35
Yes, I did check computer.In diagnostic mode 3, I try to see if any codes were stored and I only rec'vd code: 55, which means no codes stored. I also must note that I haven't been driving the car as often I used to in the last year or longer. I'll drive it around to charge -up battery every couple of days. Maybe problem is as simple as a little water in fuel or a build-up of carbon in intake area.
Sep 19, 2009 at 4:19 AM
DOCFIXIT
  • 18,828 POSTS
That's good possibility also if battery voltage drops below 11.9V even though alt. good ECU drops out and shuts engine down.
Sep 19, 2009 at 7:39 AM
