1990 Nissan Maxima Engine not stable
GODWIN
  • 1990 NISSAN MAXIMA
Engine Performance problem
1990 Nissan Maxima 6 cyl Front Wheel Drive Automatic Unknow miles
tachometer goes up and down when in neutral and parking positions
Wednesday, July 8th, 2009 AT 6:05 AM
Do you have a check engine light On and when was the last tune-up.
Could be a problem with IACV-AAC valve
Wednesday, July 8th, 2009 AT 6:27 AM
GODWIN
There is no check engine light
My old engine and gear were replaced with another used engine and gear. After installation, I had a test drive and it was good. Subsequently a problem developed. Each time you engage the gear the engine running drops and goes off. I guess an electrician adjusted the switch or something and it started working. The engine has been high even after tuning to the lowest. But it doesn't just stay high, the tachometer sometimes takes a dive and it barely resists going off. Sometimes it goes off.
Wednesday, July 8th, 2009 AT 6:49 AM
Check the IACV_AAC valve, FICD and throttle position sensor and airflow meter comeback with some results.
Wednesday, July 8th, 2009 AT 10:15 AM
