1988 Nissan Maxima brake and battery light
187,000 MILES • 6 CYL • FWD • MANUAL
DRVNGRANGE
On my way home today both my brake and battery light came on. My friend said that could be an alternator problem, but i just had that replaced less than 2 weeks ago. Do you have any ideas on what the problem could be??
Thank you,
Adam
Feb 17, 2008 at 1:39 PM
  • 75,988 POSTS
Read the battery open voltage-put voltmeter on battery follow polarity-record the voltage. Now start the car-put headlights and heater On-record readings-
Open voltage should 12.4volts or better
While running with lights/heater should read 13.2-15.5 volts if not the alternator is not putting out or the battery is not taking the charge
Double check battery and alternator connections
Feb 17, 2008 at 2:12 PM
