Your car does NOT have a timing CHAIN. It has a timing belt. And YES if if breaks. You are in trouble, because your car has the 3.0 v6 interference engine. Interference means there is no control whatsoever over how high up those valves will go, or how high those pistons will go. When mine broke. It chopped the spark plugs up. And scored the head real bad. Had to rebuild the engine. Sorry. That is the drawback of the 3.0 v6 interference engine. Seek someone who can chainge out the belt assembly with a timing CHAIN assembly, and then she's a real tough cookie.
Saturday, October 17th, 2009 AT 9:13 AM
