1987 Nissan Maxima BRAKE LIGHTS
JLBB
Brakes problem
1987 Nissan Maxima Two Wheel Drive Automatic
brake lights are on all the time,have to disconect
battery to put out.
switch on brake pedel will put lights out when i press
in on plunger.
looking at bracket on pedel , switch plunger does not
hit anything,bracket has a hole that it goes to, as
does the A.S.C.D. switch.
Aug 12, 2008 at 4:51 PM
BLACKOP555
  • 10,386 POSTS
sounds like the switch is out of alignment, you say the plunger isnt hitting anything? there should be a little rubber or plastic plug or a metal bracket.
Aug 13, 2008 at 2:02 AM
