2006 Nissan Frontier How may I install factory cruise contr
BENNYJR
Engine Mechanical problem
2006 Nissan Frontier 6 cyl Two Wheel Drive Automatic 39k+ miles
2006 Nissan Frontier SE 6 cyl Two Wheel Drive Automatic
My truck also came without cruise control. Would like to know if is possible to have a cruise control system install on my truck and how much of a problem it would be. Thank you in advance for any info you can furnish.
Jan 16, 2009 at 9:56 AM
KEVIN12881
  • 336 POSTS
LOT of work. a lot. you will need a speed sensor mounted inside transmission (may be there anyways i do not know) you wil need a cruise contro modulator and countless other things. wires will have to go through firewall, controls mounted inside cab, vacuums wires and other stuff mounted to throttle.....I could not do it, but maybe you can
Jan 16, 2009 at 10:12 AM
