2005 Nissan Frontier fluid change
60,000 MILES • 6 CYL • 4WD • AUTOMATIC
JOSHER
  • 17 POSTS
the book recommends drain and fill every 15K or flushing every 30k. This sounds ridiculous to me and very expensive. I never pull anything with this truck and generally always drive highway miles. With this kind of 'easy driving', can I assume 60K for a flush is okay? Joe
Jun 29, 2010 at 8:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
not sure what book you have, but the manufacturer does not recommend replacing ATF at 30k miles..only inspecting it at that time. should easiliy make 100k miles without needing service if you drive under normal conditions.
Jun 30, 2010 at 12:47 AM
JOSHER
  • 17 POSTS
[quote:10161a4b6c="bluelightnin6"]not sure what book you have, but the manufacturer does not recommend replacing ATF at 30k miles..only inspecting it at that time. should easiliy make 100k miles without needing service if you drive under normal conditions.[/quote:10161a4b6c]
It is the scheduled maintence book issued with the truck. The book states under premium service the transmission fluid should be replaced every 30k with an optional 'flush'.
Jul 1, 2010 at 5:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
oh okay, yes under Premium it would be..since you don't tow though and i'm assuming you don't go offroading with it, there is no need in following the Premium schedule. You should follow the schedule labeled Normal.
Jul 1, 2010 at 6:36 AM
