2004 Nissan Frontier Whistling noise
2004 NISSAN FRONTIER
64,000 MILES • 4 CYL • 2WD • MANUAL
JENY414
Hi. When I start up my Nissan Frontier, I always hear a high pitched whistling noise. It sounds like teapot when it is heated high. I hear that sound for about a few seconds and then it stops. When the weather is colder, like in the evenings, I hear that whistle when I am starting up my truck but the sound continues for a minute or so. Sometimes, the noise even continues when I drive a short distance. Also, when I am stopped at the stop light I hear that whistle when I am changing gears or accelerating. Yesterday, I took my truck to a Brake Shop and the mechanic looked at my belts. He showed me that he was looking for frayed eyes on the belt or any fissures. He said that he did not see anything wrong. He said I could drive my vehicle without immediate repair. This has been ongoing for at least 8 months. Please help!
Apr 3, 2008 at 10:45 AM
2CARPRO JACK
  • 11,533 POSTS
Could be a vacuum leak or the idle air control motor making that noise. Try spraying around the engine with carb cleaner, if the idle changes, you have found a vacuum leak. If no leaks, I would start with the IAC
Apr 4, 2008 at 3:29 AM
