2004 Nissan Frontier spark plug replacement
2004 NISSAN FRONTIER
101,500 MILES • 6 CYL • 2WD • MANUAL
GOODHORS
What tool and/or trick is used to change the #6 spark plug (closest to the fire wall and underneath intake manifold, out of sight)?
Jun 29, 2008 at 7:50 AM
BLACKOP555
  • 10,386 POSTS
try from underneith with a wrench on the end of the spark plug socket.
maybe the motor mounts can be loosened and the motor pivoted enough to get at it.
Jun 29, 2008 at 12:23 PM
GOODHORS
There is no access from underneath available and loosening motor mounts doesn't sound logical. Gotta be a trick to this problem.
I was hoping for a response from someone ,who had done the deed. Come on you V6 owners, step up.
Jun 30, 2008 at 8:31 AM
BLACKOP555
  • 10,386 POSTS
i have done the deed on many vehicles and i have indeeded loosened the motor mounts to make the job easier for all plugs not just the one.
so you can try this or try to buy a owners manual and see how to do it the "right" way.
Jun 30, 2008 at 2:39 PM
GOODHORS
The trick is 2 universals and 2 extensions plus a mirror/flash light Not loosening motor mounts dumbass
Jul 12, 2008 at 3:25 AM
BLACKOP555
  • 10,386 POSTS
thank you mr. tech for that!
Jul 12, 2008 at 2:04 PM
