2004 Nissan Frontier Oversize tires
J1949A
Transmission problem
2004 Nissan Frontier Four Wheel Drive Automatic
I put 33in tires on my truck and a long travel suspension system. I am concerned the oversize tires will damage my transmission because I did not change the gears. The engine is a V6 3.3L
Jun 14, 2010 at 2:50 PM
2CARPRO JACK
  • 11,533 POSTS
With a little Google searching you can find a programmer to use that should allow you to select a taller tire so the trans will shift at the proper points.It should also allow the adjustment of a few other things, so read up on whichever one you select to be sure it does what you need.
autopartrr.com/store/2004_Nissan_Frontier_Superchips_FlashPaq_Tuner_Search_Auto_Parts_/page2/
Jun 14, 2010 at 3:47 PM
