2002 Nissan Frontier
70,922 MILES • 4 CYL • 2WD • AUTOMATIC
AZMIKE
Engine on my 2002 Frontier 4 cyl DOHC will run fine for a while, then run rough and dies when you slow down and rpms drop It will start again, but runs rough and dies
Aug 12, 2010 at 3:46 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Aug 12, 2010 at 5:29 PM
