2001 Nissan Frontier I've ran out of things to try....
2001 NISSAN FRONTIER
117,000 MILES • 4 CYL • 2WD • AUTOMATIC
CLIFF_WHIT
about 2 years ago my a/c stopped working...a few days ago I recharged it it worked great for one day. thought it mite be leaking so I put the detector dye in it couldn't see any leaks. by the way the compresser is working and does run. I went ahead and put the stop leak stuff in it. it also is spitting very cold water on the passengers feet. the truck is paid for so if anything goes wrong it's like to know that I fixed everything I can with it. I've run out of things to try......and not ready to shell out 300 plus dollars...
Aug 2, 2008 at 7:21 AM
LIKEAROCK6516
check your evaporator which is located under the dash on passenger side if it is leaking there it would be hard to see the dye and it would explain the cold water on the feet
Aug 4, 2008 at 1:46 PM
