2001 Nissan Frontier FLICKERING LIGHTS
100,600 MILES • 6 CYL • 4WD • AUTOMATIC
CESAR123456789
The flickering started last night. I've taken the alternator to be checked and it was fine .optima battery 4 months old and was fine. All ground wires were checked and they are all in good condition making good ground.the maintanance on the truck is 100%. the engine has a slight stumble and the flickering matches the engine rpm. as i accelerate sodoes the flickering almost to the point of going away . while the engine is not running the lights are perfect. Im thinking the ignition module but can't find any info on the net about this module. thanks
Jan 8, 2008 at 11:59 PM
  • 75,988 POSTS
Load test the battery for 10secs with ignition disable and with a use of a voltmeter on the battery, if it cannot hold 9.6 volts or better replace it.
Jan 11, 2008 at 9:01 AM
CESAR123456789
[quote:c54ed9ed9f="rasmataz"]Load test the battery for 10secs with ignition disable and with a use of a voltmeter on the battery, if it cannot hold 9.6 volts or better replace it.[/quote:c54ed9ed9f]
The battery was perfect. stayed at 11.59 for the load test. do you have any suggestion.
Jan 12, 2008 at 1:19 PM
  • 75,988 POSTS
Have the charging system full fielded this will tell who's not doing its job.
Jan 12, 2008 at 4:32 PM
