Back up lights does not work. Replaced light bulbs and check fuses, all okay. So what is wrong with my back up lights?
Feb 12, 2010 at 6:05 PM
✓Experienced Mechanic
Hi there,
Check the continuity through the reverse light switch on the transmission. The switch is on the lower R/H/S of the transmission. Here is the switch location and a guide to help test the switch:
Image (Click to enlarge)
Feb 12, 2010 at 7:08 PM
CHUCK HUTH
MEMBER
0 POST
Thanks. I had a volt meter but didn't know how to use it so the guide helped me figure out the switch was bad. I got a new one from AutoZone the lights work once again.
