2000 Nissan Frontier Truck Stalled!
GARY L. MYERS
  • 2000 NISSAN FRONTIER
  • 6 CYL
  • 13,000 MILES
Hello, I was driving my truck down the road when the "service engine soon" light came on and the truck stalled. The engine turns over but will not start. The fuel pump does work and I changed the fuel filter. The oil and transmission levels are fine. I checked the distributer cap. There was a little build up on the contacts which I scrapped off. There is no excessive moisture under the hood. I purchased a Chiltons manual and could find no reference to the service engine soon light. Any information you could give would be awesome. Thank you in advance, Gary.
Wednesday, May 7th, 2008 AT 9:31 AM
Take it to Autozone if you have one within the area its a free service have them pulled the OBD2 code/s and comeback with it, this is where we start the diagnosis
The fuel pump does work and I changed the fuel filter. If its not the correct fuel pressure nothing is gonna happen-check the fuel pressure and comeback with the readings.
Saturday, May 17th, 2008 AT 3:43 AM
