2000 Nissan Frontier SPARK PLUGS
2000 NISSAN FRONTIER
107,800 MILES • 6 CYL • 2WD • AUTOMATIC
SMALLBLOCK3333
HELLO,I CHANGED THE LEFT SIDE PLUGS ON THE NISSIAN THE RIGHT SIDE THE PLUGS ARE BETWEEN THE PLENTUM VERY DEEP ,DO I NEED TO REMOVE THE PLENTUM TO CHANGE THE PLUGS ,THE PLUGS SLANT RIGHT UNDER THE SOLID PART OF THE PLENTUM,A LONG EXT.AND SWIVEL DON'T WORK . THANKS MR.RICKY SANDERS
Oct 6, 2010 at 11:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
it can be done without removal of other components.. it is a very tight area to work in try using a 6 inch ext, then a angle/swivel socket, then attach a ext to the Rachet. best way is to use a 6" Wobbler extension. Without out the wobbler extension it is very difficult to get the correct angle.
Oct 12, 2010 at 5:18 AM
