2000 Nissan Frontier replacing fuel filter
129,000 MILES • 6 CYL • 2WD • MANUAL
MELTDOWN
Is there a switch to turn off or a fuse to disconnect prior to replacing the fuel filter? I can't find anything in the manual, and the online instructions I found don't mention anything to relieve fuel system pressure.
Thanks
Oct 18, 2008 at 3:05 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0929a4d1dd="meltdown"]Engine Mechanical problem
2000 Nissan Frontier 6 cyl Two Wheel Drive Manual 129000 miles
Thanks[/quote:0929a4d1dd]
On most newer vehicles to relieve fuel pressure all you have to do is remove your gas cap.
Oct 18, 2008 at 3:27 PM
JNOVACK
  • 723 POSTS
check under hood passangers side between firewall and battery or under truck near fuel tank on driver side
Oct 18, 2008 at 3:30 PM
