2000 Nissan Frontier Engine RPM's Fluctuate
145,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRODIE3AZ
Appx 1 yr ago timing belt broke. Friend starting new garage replaced and commented timing was adjusted. Recently checked to find set at 5 BTDC not 15 BTDC. Adjusted to 15. Week later find that RPM’s fluctuate after vehicle warms up, runs like dog. Replaced fuel filter, added fuel stabilizer, cleaned MAF Sensor, dusted out distributor and Cam Position Sensor. Operates normal for day or so then returns to fluctuating.
Apr 29, 2010 at 3:40 PM
  • 75,988 POSTS
Check and test the IACV-AAC valve and Throttle position sensor.
Apr 29, 2010 at 6:13 PM
