2000 Nissan Frontier Distributor
TJS9426
Engine Mechanical problem
2000 Nissan Frontier 6 cyl Two Wheel Drive Manual
I have replaced the distributor 3 times now and it overheats and stops getting spark, ultimately shutting down. It gets so hot you cannot touch it, for that matter the whole engine seems to run hot however the temp gauge never shows hot.
Oct 19, 2010 at 2:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
is check engine light coming on? seems as though your timing may be incorrect .
Oct 19, 2010 at 3:22 PM
TJS9426
The local parts house thinks it is a short in wiring for the ignition coil? any ideas?
Oct 19, 2010 at 4:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
i would lean toward incorrect timing over a wiring issue here.. shorted wiring to ignition coil would not explain engine overheating, incorrect timing can cause engine overheating as well as dist. overheating
Oct 19, 2010 at 4:16 PM
TJS9426
Is the timing adjustable or set? under the impression that it is preset in distributor?
Oct 19, 2010 at 4:35 PM
BLUELIGHTNIN6
  • 16,542 POSTS
ignition timing is adjustable on the Frontier..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2808.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_916.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_743.jpg
Oct 19, 2010 at 4:51 PM
TJS9426
I will be trying this tomorrow and hope this is it. If not i will let you know. If so I will definitely be donating thank you. Thank Goodness for lifetime warranty on distributor.
Oct 19, 2010 at 5:00 PM
