2000 Nissan Frontier
2000 NISSAN FRONTIER
NAUGLE5
  • 9 POSTS
How do you change the rear tail light on this truck, its a crew cab pick up
Jul 20, 2007 at 9:45 AM
2CARPRO JACK
  • 11,533 POSTS
Look for any scrwews holding the lens in, might have to drop the tailgate and look in the inner edge of the bed. Might even be plugs over the access holes
Jul 21, 2007 at 1:39 AM
NAUGLE5
  • 9 POSTS
[quote:641ee9214d="2CarPro Jack"]Look for any scrwews holding the lens in, might have to drop the tailgate and look in the inner edge of the bed. Might even be plugs over the access holes[/quote:641ee9214d]
Been there, no screws no where !
Jul 21, 2007 at 1:46 AM
2CARPRO JACK
  • 11,533 POSTS
Something holds it on. Have you looked from underneath for access?
Jul 22, 2007 at 12:07 AM
NAUGLE5
  • 9 POSTS
[quote:c38c9b4467="2CarPro Jack"]Something holds it on. Have you looked from underneath for access?[/quote:c38c9b4467]
Yes, its weird, im subject to getting a screw driver and seeing if i can pry it off, just dont want to break it, looked everywhere !
Jul 22, 2007 at 12:15 AM
2CARPRO JACK
  • 11,533 POSTS
To change tail light housings you must first remove the factory bed liner and the bolts are now within sight and easy to remove
If you are talking about the passenger side taillight, it is a recall issue with some Frontier models. See the Nissan web site for details
Found this on Google
Jul 22, 2007 at 12:41 AM
NAUGLE5
  • 9 POSTS
[quote:2ffaf26720="2CarPro Jack"]To change tail light housings you must first remove the factory bed liner and the bolts are now within sight and easy to remove
Found this on Google[/quote:2ffaf26720]
Thanks for the help, this is a crew cab pickup, the tail lights are not attached to the bed, will lift the liner to see. Thanks again
Jul 22, 2007 at 12:46 AM
