1999 Nissan Frontier voltage regulator
174,000 MILES • 4 CYL • 2WD • AUTOMATIC
THAT ONEGUY
new battery, new alternator, after running 2 to 3 days the battery runs down again. Help...If you say voltage regulator, where is it? I've been looking for it and can't find where it is...
Oct 18, 2008 at 11:54 AM
  • 75,988 POSTS
Check fuse A 80amp,fuse no.36 7.5amp, and fuse no.11 10amp.-all tests good-
The voltage regulator is built into the alternator but it can be replace. Overall get the alternator and battery load tested again making sure its producing an output and battery taking the charge
Oct 18, 2008 at 1:05 PM
