1998 Nissan Frontier Fuel Filter
1998 NISSAN FRONTIER
196,000 MILES • 4 CYL • 2WD • MANUAL
KEVINLOUISEATON
whats the procedure for changing fuel filter??
Mar 29, 2010 at 9:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter is located under the vehicle near the fuel tank. Relieve the fuel system pressure. Remove the fuel filter shield, if equipped. Disconnect fuel lines. Remove fuel filter from the bracket. To install: Install or connect the following: Fuel filter to the bracket Fuel lines Fuel filter shield, if equipped Start the engine and check for leaks.
https://images.2carpros.com/forum/automotive_pictures/261618_0996b43f80209870_1.jpg
Mar 30, 2010 at 1:26 AM
