1997 Nissan Frontier truck wont go into gear
200,000 MILES • 4 CYL • 2WD • MANUAL
FRITZDACAT
I have a nissan 97 hardbody. I have never had any clutch or transmission problems, Yesterday I went to drive and the truck wont go into any gear, With the truck of it shifts into all gears smoothly with no problems. If I put in gear and then start the truck ,,the truck will jerk forward while I have my foot on the clutch. I have replacedthe slave cylinder and a new master cylinder. I bleed the line real good and still wont go into gear. What is the problem?? I don't won't to purchase a new clutch kit if there is something else that might be the problem,,help!!!!!!!!!!!!
Nov 23, 2008 at 8:39 AM
  • 75,988 POSTS
Sounds like a clutch assy is needed-with both the slave/servo and clutch M/C being replaced.
Nov 23, 2008 at 8:57 AM
