1996 Nissan Frontier
125,000 MILES • 4 CYL • 4WD • MANUAL
B2M2W2
emmisions code po443 ? won't pass state inspection
Mar 16, 2009 at 10:56 AM
TED-E-DEE
  • 109 POSTS
It's 4/22, I'm not sure you still have an issue as it's been over a month since your post. If you do, I'm not sure what your question is. Do you have access to info on code p0443 ? Are you looking for info on this code, & diognostic procedures ? I can tell you that p0443 is EVAP control system, purge valve C fault. Now you need to begin diognostics for that fault code. I reccomend renting "Mitchell 1" service manual for procedures. They have all the info you need to diog. & repair
Apr 22, 2009 at 4:44 AM
