1968 Datsun 1600 battery
1968 DATSUN 1600
130,000 MILES • 4 CYL • 2WD • MANUAL
DON6345789
I have a 1968 datsun roadster 2000. Charging system works fine if my headlights are not on. If headlights are on the battery does not charge. I have changed the regulator.
Don
Dec 6, 2009 at 10:00 AM
  • 31,937 POSTS
Hi there, i would like to know what the loaded charge rate is, that is what the alternator output is with the lights, heater and wipers on.
Mark (mhpautos)
Dec 6, 2009 at 10:08 AM
DON6345789
When i took it to the gas station it was charging around 14.
With the lights on we were around 11. We didn't turn on the heater and wipers.
Thanks for getting back to me.
If you need more in info I will go to the station and get all the numbers for you
Don
Dec 6, 2009 at 10:50 AM
  • 31,937 POSTS
Hi there, with a load on, (the lights are enough to prove a point here) the alternator is not working under load, i would be having it overhauled and then re checking the charge rate, depending on battery condition you will be wanting 13.5 ~ 14 V
start here.
mark (mhpautos)
Dec 6, 2009 at 11:49 AM
