1992 Nissan Axxess car runs very slow 25km/hr max.only.
1992 NISSAN AXXESS
RASDY
Engine Performance problem
1992 Nissan Axxess Two Wheel Drive Automatic 23300 miles
hi,
anybody can help me regarding my car nissan axxess 1992 model,everything fine till the next day I start it and it start but turn off by itself after a minute,I check the fuel it was low, I bike to the gas station to get some gas ,I filled with 2 gallons,the it start continiously but when I pressed the gas pedal to the max the car just barely move,the transmission was okey since it can shift from drive to reverse gear but it needs to press the gas pedal to the max then barely move forward and backward,I tried to drive it around the block but it can only run 25km/hr max even though i press the gas to the max.I dont know it its the fuel pump or fuel injector or fuel filter???any body can help me an advice what to check.Its a big help especially to the poor guy like me.
thanks a lot for your time and effort regarding this matter.
thanks you very much.
rasdy,
Aug 29, 2009 at 2:06 PM
Check your fuel pressure if okay -test the throttle position sensor
Aug 29, 2009 at 10:26 PM
