2001 Nissan Altima Vibration Above 60 MPH
PAULYT23
I have a 2001 Nissan Altima with 86,000 miles on it. I noticed that my car was pulling a lot to one side, so I took it in for a wheel alignment. The shop realignmed my car and had me get two new front tires. After the alignment, my car drove straight, but I noticed a lot of vibration in the steering wheel and seat. I took it in to a different place to get all four tires balanced, and it helped, but the problem is still there after I go above 60 mph. Is there vibration because of uneven tire wear, since I have two new tires and two old ones, or is there another issue here? Thank you.
Paul
Jun 3, 2007 at 3:10 PM
SERVICE WRITER
  • 9,123 POSTS
Why didn't you take it back to the first shop?
It sounds like a bent rim, tire balance problem. If you feel it in the steering wheel, then it is in the front. The new tires need to be checked for a wobble, rim problem or balance issue. The first shop i would expect to do this at no charge, unless somethinng else is unlikely uncovered.
Jun 3, 2007 at 3:27 PM
Suggested Repair
Return the car to the alignment shop and have the new front tires and rims checked for wobble, a bent rim, or a remaining balance problem. Vibration felt in the steering wheel points to the front.
Conversation Summary
A 2001 Nissan Altima pulled to one side, so it was aligned and fitted with two new front tires. It then drove straight but vibrated in the steering wheel and seat. Balancing all four tires reduced the vibration, but it remains above 60 mph. The expert says a bent rim or tire balance issue is likely, especially in the front, and recommends having the first shop recheck the new tires and rims for wobble, damage, or balance, typically at no charge unless another problem is found.
