1994 Nissan Altima Stalls in Drive
ESJAYWARES
87,000 miles 1994 nissan altima starts up fine but would shut off at traffick light when drive gear is engaged. car wont move until after engine is turned off for a while and then restarted. sometimes engine acts like is going to stall and then would pick up and be fine for a while before problem sets in again.
Apr 22, 2007 at 12:57 PM
  • 75,988 POSTS
[quote:30b146f405="esjaywares"]87,000 miles 1994 nissan altima starts up fine but would shut off at traffick light when drive gear is engaged. car wont move until after engine is turned off for a while and then restarted. sometimes engine acts like is going to stall and then would pick up and be fine for a while before problem sets in again.[/quote:30b146f405]
Check the throttle position sensor and idle air control valve.
Apr 23, 2007 at 10:27 AM
Suggested Repair
Check the throttle position sensor and the idle air control valve.
Conversation Summary
A 1994 Nissan Altima with 87,000 miles starts normally but stalls at traffic lights when Drive is engaged and will not move until it is shut off and restarted. It sometimes nearly stalls, then recovers for a while. The expert advised checking the throttle position sensor and idle air control valve.
